July 4, 201510 yr I wonder if anyone can help ? my setup is 328rpm Q100 , S12S controller (current limited ) ,LCD3 . motor is used as a mid drive. The problem I have is that it takes several rotations of the pedals for the PAS to kick in and in those rotations it feels as if the motor is acting as a brake, pedal past that and it all seems fine. If I feed in a few rpm on the throttle then apply PAS ,no problem and stopping pedaling and restarting is fine as long as the motor has a few revs on it. Is it possible that I have parameter P1 set wrongly (214) I have found conflicting vies on that. For what its worth, the setup on the throttle works a dream being able to drive through 21 gears regards John
