PASS Wiring question
Andrew Wingrove
87
York
www.simplicityin.training
Everything works on an Ebike I have except the PAS. Looking at the controller the wires are in the order red green yellow. Does this seem to be in the right order, with red the +5V, Green the signal, and Yellow the Ground. ( Controller is a KT36ZWSRT-EP03 )
wheeliepete
2,047
757
Devon
As there is no common colour coding on these components unless bought together from one supplier, you will have to swop wires around to find the right combination. You can prob. take red as +, so try changing the order of the other two.
Andrew Wingrove
87
York
Thanks for the help, made up a new connector from one with the closest colours, and decided that black is ground, then yellow must be ground on the controller. Plugged it in and waved a magnet near it caused the wheel to spin.
Sent from my iPad using Tapatalk
8,737
Glad to see you used logic and found the correct sequence.
You did presume correctly, sometimes China colour coding/sequence can be all over the place but as a general rule and as you have found 5v/+ can be Brown or Red, Gnd Black or Yellow, any other colour is used for signal.
Andrew Wingrove
87
York
Hi Neal, Yorkshire Tea, and logic in the end wins the day.
Reactions: Nealh
8,737
Yorkshire is also my preferred brew.
Often wire sequence/pin outs need re-arranging and is the bit that flummoxes some also some peripheral wiring connectors come loose for the user to select correct sequence, a good idea with sm connectors.
jegthepeg
Jun 4, 2019
I connected my 250w controller up as all the plugs were designed to be idiot proof in that they had unique male/female connectors on .I had to buy a new PAS sensor and luckily it came fitted with a plug compatible with the controller wire, however I accidentally pulled the plug of leaving 3 wires that do not correspond to the 3 colours in the wire from controller. How do I re-wire the plug? Photo 1 shows 3 wires from sensor, no.2 shows the black pug from controller.
3,994
These are the connectors that you cab get from Ebay.
You have a choice on how to fix it. You can buy the connector block and pins, then use thin pliers to crimp the pins to the wires and insert into the block. It's a bit fiddly, but that's what I normally do. After a lot of practice, I can get good crimps.
Alternatively, you can buy the connector with the leads already attached, cut the leads a couple of inches from the connector, then solder the wires together and insulate with thin heat-shrink tube. That's what I do when I'm in a hurry.
Finally, this is how I do it on my own bikes. cut off the connectors, solder the wires together and insulate with heat-shrink tube. That's the cheapest, quickest and most reliable way to do it. In all probability, you'll never want or need to separate the wires again, but in the unlikely circumstances that you did, it takes one second to cut them, which is quicker than disconnecting, then you can resolder them to reconnect.
Whatever solution you use, the colours go brown to red, black to black and yellow to white.
manman94
158
Netherlands
I have red black and white coming from this Bafang controller it says on the website this is pedal assist connector,the cable that comes from my bike is red blue and black .
I'm sure red white and black are throttle connectors has anyone an answer .
manman94
158
Netherlands
This was originally a waterproof connector I cut that off and added the sm plug myself to fit the connection coming from my bikes pedal assist
thelarkbox
1,519
476
oxon
removing the screws from the end caps and securing the mosfets to the case for heat exchange should let you pull the pcb from the controller case letting you check the silk screen print for labels where the wires connect. Though a google image search will probably provide the info with less hassle..
3,776
Different controllers from different manufacturers can have all sorts of colours on any connector, but red, white and black is nearly always (not always) throttle or speed sensor.
8,737
Connect up and try , if the wiring Id comes direct form the Bafang website take it that it might actually be correct..
Reactions: notsoguilty
manman94
158
Netherlands
Here you see the controller and what they say is the pas connector red white and black,but on the pas sensor that comes from my bike it's blue black and I think orange .
So which combination would I assume.
Any help much appreciated
