Pedal sensor problem
Iceman
I replaced a faulty pedal with a replacement from amazon. Now it works but when I pedal backwards it also works. Can anyone help?
17,244
your controller is programmed for DH pedal sensor.
Normal sensor will send pulses when you rotate the cranks forward or backward.
you need a King Meter dual hall pedal sensor which sends pulses only when you rotate the cranks forward.
8,754
Don't pedal backwards.
