Hi All Need a new pedal sensor mine got caught in the chain ring which made a wright mess of it what I wont to know will any sensor work John
Hi Neal There is one on the Bay got 8 magnets mine has 9 got a yellow plug mine has to i bought the kit off the Bay from Germany he wants £32 bit much so will it work JohnMost sensors come with a magnet ring all should work as long as it is wired right, two types of sensor fitting adjustable sticky on ones which also are better being cable tied or a bracket one which is retained by the b/b retaining nut/ring.
Hi Nealh I ordered that one hope it`s wired right John£32 you having a giraffe, how about this one for £14.
http://www.ebay.co.uk/itm/ELECTRIC-BIKE-E-BIKE-PEDAL-ASSIST-SENSOR-24V-36V-48V-waterproof-connector-/141803825251?hash=item21042aa863:g:-IMAAOSwI-BWIZ6U
Hi Nealh It`s a kit bought of the Bay off a German man are most of them weired rad black white will check out Wuxing Thanks for your help JohnYou didn't say which bike you had. Wuxing make a lot of components which are fairly generic on Chinese branded/ sourced components. The yellow 3 pin connector should be good also looks to be a LH fitting so no need to get caught in the chain again but some will fit on either side.
Look on Pedalease's web site it may give you more info.
