Wanted Peddle assist sensor for Hollowtech
8,771
Try Woosh or ebay for BZ10C though will come from China via TBK shop.
My BZ10C was about £10.50 off Aliexpress I loathe to pay UK sellers for doubling the price for the same thing originating in China.
3,994
Use a normal cheapo one on the left side. You reverse the bracket so that the sensor reaches forward instead of back, drill or dremmel out the magnet disc to 25mm hole and chuck the plastic spacers that are between the BB bearing holders and the frame. You might have to thin down the magnet disc a bit in the centre.
37079
37080
Reactions: Manc44
pajtaz
84
7
Netherlands
Two places for you to buy.
The first one is not with waterproof Julet connector. However maybe Dan (guy who runs the webshop) can put a Julet connector on there with your requirements, for extra fee. You can ask him. I use this sensor, it works perfectly.
The second one is the one with Julet waterproof connector. This is the one you need to work with the ring on the right side, on the Hollowtech BB.
You can also buy the split ring from the same shop. This split ring magnet is the one I use on my Hollowtech.
