Pro Connect TopLight XS connection question
rock_hopper
17
I noted this week that my rear light was no longer working on my Pro Connect so have today had a little look.
The connections looked a bit fragile so decided to redo them BUT didn't note which way around they went ! Have one cable with a white strip and the other solid black, one terminal has a 'lightening bolt' the other a circle (earth ?). Can a kindly knowledgable person advise the best way to put it all back together so as not to blow anything up !!
Managed to get the bulb out eventually (bit of a struggle) and it seems to be a Phillips 6v 0.6W - so if the redone connections don't fix it l'll be off hunting for a replacement or might plump for an LED version.
tillson
5,253
3,197
The wire with the white stripe goes onto the lightening bolt terminal, well it does on my bike anyway. If you have a filament type bulb, then it makes no difference.
I don't think an LED light will work on you bike if the power is delivered from the battery. Others have tried and failed.
