I took out a un named electric bike today, step through model. Looks new but prob been sitting around for a while. First prob charger u/s got another one sent. I took it out today,problems started when switched on not wanting to work to well The key has off and two on positions, position one throttle which works tilll about 10 mph, let go throttle whilst pedaling and motor goes faster ( 15mph ish) than you can pedal stop pedaling and cuts out as should unless throttle engaged but top speed back down to 10 ish.
I think the key same in the second postiton.
The pedal sensor also works sometimes in that you have to pedal a few revolutions to get power for throttle, but sometimes you dont need to pedal
There is also a button by throttle I am assuming a 2 speed button which does nothing in any position you try.
I hit a slight incline and it started cutting in and out with or without throttle and at other times. I did about 3 miles in all and the battery registerd about 37.6 volts at the end and has now been charging about 2 hrs. The battery pack is a 36v 12ah ish
The brake cut outs seem to work fine.
I wonder if anyone has any advice they can offer me as I am puzzled any help appreciated.
Well after being charged till full for 3 1/2 hrs it puts out 39.9 volts will recheck in the morning
regards
Fatts
regards
Fatts
