Recelled
Sniper45
33
Hi I am thinking of buying a kalkhoff agattu with the Panasonic motor and battery how much would it cost to have the battery recelled it 36 volts also its 350watts can I make it 250
30,855
The 350 watt crank drive Panasonic unit cannot be changed to 250 watts rating. Its internal circuit board is encapsulated and sealed into the crankcase half. No spares are available, it's repair by replacement.
Jonah
882
246
EX38
I suspect it’s a 26v Battery. Not aware of Panasonic making a 350w motor. Do you mean the battery is 350wh? If it is 26v, replacement battery available from
Jonah
882
246
EX38
Post crossed with Flecc. He’s the expert.
30,855
No you could be right in this case.
Panasonic did also make 350 watt units, but I'm unaware of Kalkhoff ever making an Agattu with them.
However they also market in the USA and Germany of course, both where 350 watts is commonplace, so could have done briefly.
