Recommend me a 2nd ebike
AndyBike
1,755
747
Im really in need of another, and i've decided not to go the conversion route, as i reckon im not skilled enough and ok maybe too lazy to go to the trouble. But currently i need to go some places where ill have to leave the bike locked up and fooked if thats going to be my custom built £6 1/2k full suss 29er
Top end money is £1000. No higher, and to be honest if theres something reasonably reliable for 500,600 or£700 I'd go for that, as long as theres more positive reviews that negative ones.
I'm under no illusions it isn't going to be a well specced bike, but needs must and having the 2nd i can use occasionally to go to town and happily leave it, locked, albeit with a high end lock.
Im 6'3", 13 stone**. Distance is probably going to be 10mph round trip.
Any suggestions ?
Must be readily available in the UK(Scotland) not be mail order* I was looking towards Helfrauds
* With the exception of Woosh. I actually like the look of that Faro. Could well tick the boxes.
** ahem :(
Bonzo Banana
819
474
If its not mail order and needs to be £1000 or less I guess you are in the territory of Halfords, Decathlon, Evans, Argos, Go Outdoors and maybe one or two others that aren't in my area. When I've gone into local independent bike shops I don't see many £1000 or less ebikes and when I do they are often pretty awful. I went into I think its Tiley's in Weymouth a couple years ago and their cheapest ebike was a £800 Viking model and at the time Parkers of Bolton were selling the same model for £400. Now the Parkers of Bolton version would have been a return. When I say return I mean probably stock that went to a retailer wasn't sold and then returned rather than a customer return.
The single speed version of the Carrera Impel comes to mind. A very low maintenance simple ebike which is around £1000 which will probably take some abuse without issue as even if it gets some people pushing it about in a bike rack outside a shop there is not much to damage. No derailleur to break or derailleur hanger to bend. No crappy suspension either. Looks like a good workhorse of a ebike.
I'll admit though that if I had £1000 to spend on an ebike I wouldn't limit my options but look everywhere to find the best deal for me including places like ebay and Amazon.
Andy-Mat
2,214
564
78
Any suggestions ?
That said. I've a pile of good bits, 26" disc wheels(Pro4) hope X2/E4 brakes, posts, saddles etc. So if you have something in the classic design format (straight top tube) and dont mind sending me 1/2 a bike, for less than advertised price, that would also suit me. If its suitable to yourselves also.
** ahem :(
I have been most happy with the 2017 Stark City Bike, the initial offering from Stark, since 2017.
The basic bike costed $399, and with all the extras, except GPS, including a second batter, transport and import fees, it cost around 930 UK pounds, here in Germany.
It took me a week or so to get the dead battery sorted out with the loan of a recovery battery charger, but that battery has worked fine since and only cost me the return postage. A headset bearing was wrongly sized at the factory, and they sent me a new set, which I installed and got perfect steering.
I do believe their processes are much better nowadays.
Positive points:-
1) All parts are standard Chinese, so if anything goes wrong, easy to replace without any thought as to company politics like the mid motor comunity shafts its customers with. For example,one of the Bosch batteries costs as much as my bike does with two, and you have to pay for installation if the guarantee is up! The same for the Bosch motors, but anyway they are also out of your price range anyway!
2) strong construction, with an easy and rapid method to swap the battery, which also allos the bike tom be folded in hal if need be.
3) Spare keys for the bike and batteries supplied, as were spare keys for the heavy bike lock chain. Locks that I have been unable to pick, but like many, a disk cutter may be its downfall, which is why I use two, and a sensitive alarm, one that even strong gusts of wind set off occasionally in the back yard!
4) 26" Wheels, with medium fat tyres for both comfort and hard wearing.
5) Front and back suspension, to shield my old back from sudden, boneshaking roads. I myself will noot be happy on any wheel smaller than this.
6) Two huge panniers are in that price I quoted, as well as a middle bike stand, that holds the bike vertical and the rear motor free of the ground, even with full panniers.
7) Ibought a replacement rear light with a brake light, but have not got around to fitting it yeat, back problems this last 12 months...
8) 250 Watt motor, that manages to pull me up the steep inclines in our local mountains, which is MOST comforting.
9) I seem to manage about 50-60 Kilometers a charge on the larger battery, but its very variable, and I have not bothered to measure anything exactly.
10) The controller let in water on a very rainy day, and condensation made it difficult to see the display. So I took it apart, dried it out and carefully sealed all the joints that let in water. Easy to do and most effective. No problems since.
11) No "single point if failure" as all mid motor e-bikes have, that is, if the chain breaks, this bike (and my previous bike) will get you home on the battery, riding, rather than having to push!
It has not yet happened on my Stark, (still original chain), but mid motor bike chains must carry the FULL motor torque and the FULL Human torque, which they were never designed for, and wear rather fast and occasionally break! My first e-bike chain did break some 10 Kilometers from home, I rode on the battery all the way back, just as it started to rain!!
12) My main costs are are approximately yearly tyres and tubes and brake pads.
13)The original brake calipers had a plastic adjuster that UV licht destroyed in about a year on the front, (the rear one is shielded by the panniers), I replaced the unit with a full metal unit, repaired the original one to also be full metal, and changed them back, as I was mot happy with the performance of the original brakes. They stop me in emergencies almost to the limit of my holding on!!!
This is the bike I have, it is still being made and sold at the original price (don't forget transport and import duties on top!):-
This is a video of the unboxing and building of the same model, except that I picked white paint:-
Stark appears to have got more expensive since 2017, so
Over here, sadly Stark Bikes are the subject of cricism from some bikers who have given out anything up to €5,000, for mainly mid motor bikes. They apparently are "racist" when it comes to owning a cheap Chinese bikes, but quieten down when told that the are also riding a Chinese bike! Funny really! They bought believing it was German production....
And some of the loudest ones were completely shut up and blown away when I said lets swap bikes for an hour or so........this has happened a few times only I might add.
After a short ride, they seem to suddenly realise that they may have made a poor choice with the price, and that the Stark accellerates better, especially when the battery is full, and this all helped to quietened down their negative comments.
But they were not happy campers....
Some mid motor owners I have met (all the e-bikes that I know personally bought Bosch, have already had replacement motors due to he way the big plastic gears, on early motors, apparently did not take kindly to heavy riders, going up mountains, with full power!
Whether this has been 100% fixed on the later versions, I have no idea, as I have no interest in finding out, but the single point of failure remains of course.
There was a HUGE HULLABALOO in the biking press here in Germany, some of which can still be found on the internet, even today, about the motor problems some years back, but which does seem to have quietened down.
I must add that I am an avid DDIYer, especially with bikes, even as a young lad, which of course keeps the costs down to a minimu. But if you are not, buy something from an LBS close to your home. Do not expect them to repaor a bike YOU imported!
regards
Andy
PS. I have just written this and I am happy that nothing major has been missed out (or minor either), as I have only been MOST impressed with my bike, even with the early teething problems, with my it. And 5 years on, I am sure that those problems are long gone.
regards
Andy
Bonzo Banana
819
474
Positive points:-
regards
Andy
regards
Andy
Sounds like you are pretty much clued up how to fix issues and maintain such bikes. Many of the ultra cheap ebikes come poorly assembled but with a little bit of time can be sorted out to a good standard and made very usable and reliable. I personally would not buy an ebike with joke suspension but that is probably my only restriction. However I've never seen very cheap ebikes like that available to buy locally. Probably the nearest to it is Argos who just shift boxes and cannot provide support at all. They occasionally do some good deals on ebikes. However I think the OP is looking for a ebike that works without any issues day one and is very easy to maintain and durable. He doesn't want to hammer an ebike into shape so to speak.
Andy-Mat
2,214
564
78
Thats the beauty of the Stark, it comes "mostly" assembled, and you need to supply the finishing touches. Naturally, when I assembled mine, I checked everything else as well, which I am pretty sure that most people ordering such a bike would also do, but I would not take it to an LBS for assembly, that would be spoiling the whole Stark concept for me personally!
I personally have only put together one Chinese bike, but that was not "poorly assembled" in any way, and if it was, I would have been at least 50% to blame for any problems!!!! Many might say 90% to blame.....
May I ask, how many have you personally assembled, finding problems (please elaborate what problems you are talking about!), to enable you to make such a generalised comment?
But we must ignore buying at Halfords I am told, as apparently some of their shops actually make extra problems for the customer to find.....
I was lucky, having had a really great Dad, a WW2 veteran, who showed me how to maintain and repair my push bike (and later cars!). He has been dead now 46 years on June 30th, and I still think about, and miss him, every single day!
Not everyone is that lucky to have such a clever Dad of course.....
Andy
Bonzo Banana
819
474
Andy
I've seen reviews where people complained that their £80 bicycle at Halfords had a clicking bottom bracket after 6 months of use and it was clear they did no maintenance to the bike. The bike in question had a loose bottom bracket which need fairly regular maintenance it wasn't sealed. Some people have unrealistic expectations.
AndyBike
1,755
747
When I worked with a bike charity repairing peoples bikes it was clear that the majority hadnt a clue about doing any sort of maintenance, right down to not even knowing how to change or fix a puncture. But i dont see that as a slur on them, rather its not in their life experience where practical things are not the norm for them. Much like my Dad. He was principle engineer with bae systems, and did formula stuff with the slide rule, on our subs and warships, but when it came to actual practical things, like a bit of basic bike repair, he was utterly lost.
I know I said no mail order, but thats probably more down to the stories i see posted on here daily, of new to the market companies offering Chinese ebikes, that dont appear to work within 3 months of them being bought, which is why i added Woosh to my list of possible sources. I know nothing about them, but they are affiliated with this place, and you do get the idea their bikes are put together with care. Amongst the best of the mail orders on £999 bikes available in today's market.
As such I think I'd be happier buying Woosh, than from a halfords even if i lived next door to it.
I'll see what they can offer when whomever at Woosh finally gets out of bed lol. It will do for me for city center trips, and i can leave it on loan to my nephew who occasionally hires one of the Go Bike ones, so at least its getting the use and not becoming a wallflower for much of its life.
Sorry, is this addressed at me, or are you still replying to Bonzo.
All the bikes in my signature I've built from the frame up. Which is probably more than 30 of my own to be totally correct, as some i didnt complete. Plus did some volunteering fixing, building for a charity, so probably a couple of hundred more. Mechanical im ok with, its electrical im currently clueless about, and again to be honest, thats because i dont feel like immersing myself in that part of the subject. Only thing I cant do is wheels, and thats because i cant be bothered. Were that notion to take me, I'd have no problems learning.
RoadieRoger
746
217
Look at the Ebikes from Woosh and NCM , good specs for £1000 and satisfied Customers . In Woosh`s case plenty of help from them on this Forum concerning their bikes or those of other Manufacturers .
8,801
If worried about it getting nicked then you need an ebike that might be less nickable and one that even you would never think of riding, one has to think completely out of the box and go for a bike the total opposite which you are looking for. A step thru will be one of the least desirable amongst the low life scum who nick bikes , one with panniers and a non modern look. The ideal bike would be a kudos safari for town shopping or visits, no need for modern looking bike which is more pleasing to the eye of the low life scum.
8,801
Tbh some of the Woosh bikes look pretty good and I would class as definitely in the nickable class.
GLJoe
853
407
UK
Im really in need of another, and i've decided not to go the conversion route...
...Top end money is £1000. No higher,
I've recently been looking into this for a friend (honest guv ... I swear its not for me ...) who has a cycle to work scheme budget of £1000.
After having looked around, frankly I really, really don't think the halfords type £1000 ebikes are worth going for. In the end I've advised them to consider stumping up a couple of hundred quid more and going for a woosh.
If you're concerned the bike looks a bit too nickable, I'd seriously consider doing something to make it look less attractive! short of deliberately scratching it up. Maybe cover it with my little pony stickers or something ??? ;-)
Andy-Mat
2,214
564
78
I like your post, it smacks of truth, accuracy, knowledge and honesty.
regards
Andy
Andy-Mat
2,214
564
78
Thats a hell of a lot of experience, you are possibly one of the very few here that can honestly say that.
Thanks for your post.
Andy
AndyBike
1,755
747
@Andy-Mat Thank you for the compliment.
Im a non driver so bikes have been my life's passion. Freedom to get out. I live myself in a 3 bedroom flat, and the two spare rooms are designated as the 'tool room' which is a furniture making workshop, complete with all the proper machinery, and the other room is known as 'the bike room' where i keep all the bikes, stand, specialist tools and try to do the builds/repairs in there. Nice to have these options.
TBH I prefer to do things myself. Not that i dont trust bike shop mechanics- though in truth theres only one i do trust and he's fully qualified in Cytech. But that costs money, and im Scottish lol.
I'd rather not pander to them to that degree Nealh. I have to buy it, and be seen riding it lol, and while what you suggest would limit its nickability factor, every bike E or not is a target.
Its just about limiting loss should the worst happen.
I am concerned about bikes getting nicked, having had one nicked, and nothing could have helped there as i was riding the damned thing at the time lol.
My house insurance should cover that eventuality, but its about limiting loss and a 2nd cheaper bike would be a better plan i think.
Having a bike nicked invades my dreams and i get a recurring dream where the big ebike ive misplaced, forgetting where exactly it is and embarking on a strange multi faceted journey trying to find it, but never actually getting it, then waking up and remembering, Oh there it is in the hall. lol dreams eh,
But for sure a sign that worry is invading the nightscapes, and the lesser costing bike, covered by my home insurance i think would put paid to them.
I do that all the time. look at the thread title, then type a reply without actually reading the post.
I've mentioned Woosh twice, and even put in a link to one I think would be suitable ;):D
Andy-Mat
2,214
564
78
@Andy-Mat
Have you used GPS Trackers? I have, though I do not claim to be an expert, they are very easy to use. There are even trackers made for bikes that are hidden in the rear light, which is a good place as the plastic only reduces the signal levels slightly i believe.
You really only need to find a cheap SIM card for the tracker, and all commands and information are sent and received using text messages.
To make it even easier, Android (maybe iPhones too) have cheap Apps that will do all the sending and decoding of the received messages for you.
My last tracker, glued under the saddle, overheaded on a hot day last year and the power supply and charger part expired, so i stopped using it as it was too much hassle to change batteries when it needed charging. But I really must buy me a new one.
The ones I had were accurate to within a few meters in actual use (closer than claimed by the manufacturers), you could even track a car and know in which lane it was driving on a motorway for example.
Some car trackers have an output for a relay (maybe useable on an e-bike too), to cut power to the petrol/diesel pump. On a bike, it could say sound an alarm for you, whe you know you are close to where your bike is, for example.
Just a thought
Andy
AndyBike
1,755
747
Im hoping it doesnt come to that Andy lol. but it is a good idea to have something attached to the good bike in case something happens to that. Burglary or such. Which is touch wood unlikely, but cant say never.
Andy-Mat
2,214
564
78
I forgot to mention that you can set up a GPS tracker to do many things. Like if vibrated, it sends a text to your mobile phone immediately!
Even if you are at the back of Tescos and you forgot to set it, you can still set it without moving an inch!
regards
Andy
Reactions: guerney
