Remove 15mph speed limiter
5,785
Slow motor, you can expect 30 km/h tops if you are light weight.
Q128C 48v 201. It starts to back off at 26km and the assist is gone by 28 ish.
201 rpm is 25km/hr at 48v. With a fully charged battery at about 52v, you should see about 28km/h. If you want more speed, you need more voltage or the 328 rpm version.
Jaomi
Sep 6, 2018
Hello, I have the yosemite biltema City sport 8 gear 6 speed.
https://www.biltema.se/fritid/cyklar/elcyklar/elcykel-city-sport-28-8-vaxlar-2000041081
Any way to unlock the speed limit on this one?
Theee are 2 loose connectors that fit each other, one measures 60v, now shown in pic connecting them fries something in the controller. Replacement on its way. Is there any way to unlock it? Disconnect white cable? It's in a different place than the picture from Andreas.
Pressing two buttons when starting gets you a C on the display, but there is not much else to do on the display as I knowIMG_20180906_093421.jpg IMG_20180906_093421.jpg
Reactions: djbaaz
