S900 lcd alternative
Andy1865
290
15
Morning all...does anybody know a good alternative of the S900 lcd on an ECOTRIC FAT26, as i cant get hold of the handlevar mounts/brackets so that any other lcd that does not have plastic mounts. The photo is the connector for the lcd and the controller is a 36v Tongsheng Powertrain(LCO3622C1H-TS23).
3,994
Make your own bracket out of a bit of aluminium sheet. it takesabout 10 minutes with a Dremmel. Mark out the holes for the LCD fixing screws first, then draw a line through them and another that bisects it at right angles, then mark the centre of the whole for the cap fixing. Open up that hole until the cap fits, drill the two LCD fixing holes, and cut/rout the outside profile to whatever shape you want. Once fixed in position, you can bend it to the correct angle. It's better fixed like that because it leaves yoyr bars free for gadgets.:
40795
similar here
40796
and here:
40797
