Sakura Charger query
Bernie2
45
The Charger supplied with mu secondhand 36v Sakura E bike shows the state of the batteries during charging namely:- Red - 0%, Orange - 80% and Green - 100%. My question is " Does the charger automatically shut down when it shows Green or will it carry on charging until I switch it off". If anyone knows the answer, I'd be much obliged.
The only manufacturers mark on the charger is the number G4M20211-2347-E-16
When the battery is at the same voltage as the charger (fully charged), no current can flow. Assuming that your battery's management pcb has a balancing function, this is where it happens, so don't always be too quick to switch off the charger. Occasionally, you should leave it on for a bit after you see the green light.
Reactions: Bernie2
Bernie2
45
Bernie2
45
Many thanks D8VEH. The trouble is I have no idea if my battery has a " Balancing function", so really I am no wiser. I do know however, that you should not leave a 12 volt lead acid battery on continuous charge as it will eventually damage it and therefore I am still hoping that someone can recognise my battery from the description I have given and can tell me if it has what you call a Balancing Function.
You cannot tell whether your BMS balances without dismantling the battery. Most batteries have it, but not all.
The main point is that you don't have to panic about switching off your charger. If your BMS doesn't have the balancing function, then everything will be dormant: No current will flow and no harm can be done. If your BMS does have balancing, then a tiny bit of current flows, but no harm can be done, only good.
Reactions: Bernie2
Bernie2
45
Bernie2
45
Again, many thanks for your reply. However, I am still a little confused because I have read articles specifically about charging lead acid batteries and they all agreed that leaving a battery on continuous charge between use, will shorten its life over time. From what you are saying, it seems there is no point in having a charger that switches itself off on the basis that no charge will flow anyway, once fully charged, so why do manufacturers bother to make batteries that switch off ? I am not trying to be argumentative, it is simply that I am getting conflicting information about charging lead acid batteries and all I want to know is whether to leave mine on charge overnight or to switch it off when the green light appears. And of course, it would be nice to know if my charger has or has not the shut down facility.
Reactions: VictoryV
Sorry, are you saying that you have SLA batteries? If so, disregard everything I said before and switch off your charger as soon as it goes green. I was referring to lithium batteries.
Reactions: Bernie2
Bernie2
45
My apologies, I should have mentioned my batteries are Lead acid in my original query but I am grateful to you for taking the time and trouble to reply.
All I need now is to know if anyone can confirm if my charger switches off or not because at my age, I worry that I may forget it is on charge and if it does not switch off automatically, I will have to invest in a timed plug socket to be on the safe side.
electric.mike
342
49
grimsby
We have three bikes with SLA battery's two sakura and a powabyke,all of them state somewhere do not leave the battery's on charge for extended periods what extended means i have no idea and with this technology being so outdated i doubt i could find out.
I have never left them on charge overnight but often for an extra couple of hours with no detriment,sorry it doesn't answer your question but its all i have :)
Reactions: Bernie2
Bernie2
45
Bernie2
45
Many thanks Electric Mike. Until I find out if my charger has or does not have, a cut off facility, I think I shall do as you do and allow say an hour after the green light appears and then switch it off.
I must say I can never understand why original bike users leave you with a charger but not the instruction manual. Still, that's the way it is I suppose.
Bernie2
45
Yes I am, although I have only just started getting used to riding a bike again, let alone an electric one. The last time I got on a cycle was over 70 years ago, so you can guess what fun I had learning to ride the Sakura. I thought first of all it was too heavy (40 kilos) but I have gradually got used to it and have bought it mainly to get me to and from my Golf Club. I am getting rid of my car and going back to basics but only time will tell over the Winter whether I manage it or not.
With regard to the Sakura, as long as the batteries last and my knees don't give way, I am very happy with it. By the way, the only concern I have is the location of the battery L & N connections at the bottom of the battery case where they sit in the frame and connect to the motor wiring circut. When it rains, have you ever experienced water forming in the bottom tray and affecting the electrics, as it seems an obvious water trap to me. I have not been out in the wet yet, so don't know if I am worrying over nothing but perhaps you can enlighten me.
Regards
Bernie
Reactions: electric.mike
Bernie2
45
No, it has no indication on it whatsoever, other than the code number quoted in my original post. However, I am absolutely sure, I have seen an identical one to mine on Ebay but can't find it any longer. As mentioned, it just has the number and the three colour codes on it but I have a feeling it was advertised as a Powerbyke charger. That's all I know.
danielrlee
1,399
725
Westbury, Wiltshire
torquetech.co.uk
The only way to tell is to measure the voltage of the battery, while it is connected to the charger once the charge cycle is complete. SLA's can be safely held at a standby voltage by a charger with the capability to do so.
