One of the lightest eMTB trail toys to be found at 17.2Kg fully charged.
During the build all bearings have been replaced with new as required, fully cleaned/overhauled to a very high standard and assembled with quality greases and lubricants.
The bike wants for nothing and is ready to provide many miles of fun and smiles.
Motor: Bafang BBS01 36V 250W mid-drive motor with C965 display/controls. 9 levels of pedal assist, plus thumb throttle boost.
Battery: Samsung cell 11.6Ah downtube mount battery.
Frame: Santa Cruz Chameleon in extra small 14.5" frame.
Forks: Rockshox SID Team dual air suspension forks with 100mm of buttery smooth travel (serviced with new fluid and seals).
Wheels: Front, Hope Pro2 Evo hub with Stans NoTubes ZTR Crest rim and 180mm disc rotor. Rear, Superstar 10 speed cassette hub with Stans NoTubes ZTR Arch EX rim and 160mm disc rotor.
Tyres: Front, Maxxis High Roller II 26x2.4 tubeless. Rear Maxxis Ignitor 26x2.10 tubeless.
Brakes: Shimano XT hydraulic front and rear (serviced with new fluid and pads).
Rear derailleur: Shimano XTR with carbon cage.
Cassette: Sram 10 speed, 11-36 tooth.
Chain: KMX XXSP 10 speed.
Gear shifter: Shimano Zee 10 speed.
Handlebars and stem: Raceface.
Headset: Token TK737ABC heavy duty 1 1/8th headset with angular sealed bearings.
Seat post: Raceface.
Saddle: Defty.
Pedals: Diamond Back flats in black.
Chainring: 36 tooth with narrow-wide tooth formation.
The bike has covered less than 15 miles since the build.
£1450.
Collection from Hove, East Sussex.
Saddle: Defty.
£1450.
