Spokes !!
Del Arthur
46
That's the new rear tyre fitted......I noticed whilst fitting it, that although the rear wheel runs true, it has two broken spokes.....they appear to be 220mm in length, for 26" wheels......anyone know the best place to get some ?45926
8,800
Or go direct to spokesfromryan .com.
I expect looking from the fuzzy pic they might be 13g spokes 2.2mm, ideally remove a good spoke and measure it for a correct length as 2 or 3mm out is not good.
Reactions: Del Arthur
Del Arthur
46
Looks promising.....will take one off tomorrow, and measure it exactly......pretty sure they are 220mm.....silly question, but what does the 13g mean ?
2,849
13g is 13 SWG (standard wire gauge), an old imperial sizing still regularly used.
SWG works backwards, bigger number is thinner spoke.
8,800
Typically most of us use14g 2mm spoke for hu builds as the spoke is actually stronger due to being more flexible, Sapim strongs are my choice.
Del Arthur
46
That's the spokes ordered, 221 mm...... should be here by Tuesday.....Many thanks for the replies.......
