I've now managed to test both versions of the bike, and here are some pros and cons of both:
Cyclamatic 24v 9Ah battery, 14A maximum rated sensored controller
Pros
Cons
Beastamatic 36v 10Ah battery, 25A maximum rated sensorless controller
Pros
Cons
Pros
Great, cheap starter electric bike, that is surprisingly robust and good looking
- Good range on battery
Comes with throttle for slow, controllable maneuvers
- Strong rear servo brake in dry conditions (see cons)
Pedelec operation to maximize range of battery
Light, easy to carry battery, with key lock to lock battery to bike if you can't carry it
- Good back up support from SportsHQ
Cons
Potentially squeaky front brake, which at some stage will need to be replaced for a better assembly
Rear servo brake can be a liability in wet conditions. Prone to lock up (see pros)
- Spokes loosen fairly quickly and need to be tightened for safety
Controller power ON/OFF button can be accidently pushed whilst riding, which can make you think the bike is knackered
The position and orientation of the battery means it suffers a lot from road shock, which can cause the battery to break
Pedelec continues to operate for a split second after pedal rotation stops, which can cause low speed turning issues
Pros
36v battery and controller adds useful torque, and allows the bike to sit at the legal speed more of the time
No more burnt out hall sensors
Uprated Shimano front caliper and pads, eliminated brake squeal
Promotes less use of the gears. 7th gear is fine for most conditions
Arrive at your destination slightly less sweaty than with the stock bike
Cons
Battery attached to rack on rear of bike upsets the bike's balance, and creates a few handling issues in the wet. In my opinion, the rear of a bike will never be the right place to fit a battery
The sensorless controller has no pedelec function
Possibly less range with higher powered set-up. I have managed only 9 miles with extensive throttle use, although this battery is one and a half years old
Modding the bike instantly voids any warranty
