Hi All,
I have posted before with this problem I am having on a tricycle I am electrifying.
Details of problem
Wheels turns slowly can be stopped by hand.
Parts in use
Old powabyke brushed front hub in use new controller new throttle ( hall effect ) 36v sla ( 3 x 12v 12a batteries ) Automotive battery isolater switch for on/off switch
What I have tried and tested
Motor works fine when conected straight to battery pack ( voltage approx 39v )
I have upgraded wiring
checked for power coming to controller thats ok (39v )
power going out of controller thats ok (39V )
Tried a new controller and throttle ( controller is for brushed motors)
Throttle test I had 4.8v on red+ to black-
On signal wire from red+ to signal throttle shut 3.8 if I remember rightly, and and nearly 0v with throttle open.
The voltage may be a little out a meter a cheap one and was trying to hold throttle open with belly
There is also power down to the plug before it goes into the hub plug.
I hope someone can put me on the right track as I have exhausted my knowledge.
Many thanks in advance
Fatts
Details of problem
Parts in use
Fatts
