I have virtually finished my electric bike conversion using my Trek 3700 mountain bike and a kit from Sunlova. There are things to do like change my left hand handlebar grip and sort out a front mudguard and then there's a rear light................. work in progress is what they say. I used stainless allen bolts wherever I could and used Vaseline on electrical connections, grease and ACF50. Fresh v-brakes and new front headset bearings and new suspension forks - set on stiff setting. The idea was during assembly to help keep moisture out and prevent any gremlins by trying to do things properly and overhaul my bike as I went. I think the kit is good, things were fairly well made and I haven't had any issues apart from the bulky pedelec sensor which I don't want to use yet anyway. When I do fit it I shall see if I can modify it and make it a neater fit to my bike. My Trek has an alluminium frame and was not a heavy bike to start with so I am pleased to say with the motor and battery it is still not over the top for weight. Once the ice clears I will give it a thorough test ride.
I should take the bike outside with a blank background and take some more pictures as there is so much in the background in my garage that it's not easy to see what is what
