Whaaaay! At last - the lesser spotted Mistral; and at a couple of hundred less than a certain e-bike shop currently charges too.Can be seen here
The 200 watts is only a "rating" so doesn't mean much in real terms. For that you need to try it out. A motor rated at 250 watts (from a different manufacturer say) could well have a lower performance to one rated at 200 watts.Pity about the 200watt motor when they could have 'gotten away' with fitting the European 250watt spec for little more, as that would have sealed the award beyond reach.
Very true.The 200 watts is only a "rating" so doesn't mean much in real terms. For that you need to try it out. A motor rated at 250 watts (from a different manufacturer say) could well have a lower performance to one rated at 200 watts.
