Torque sensors
Ahmed55555
28
Hi, I have 1500w converted ebike with cadence sensors. Is it possible to fit a torque sensor as it has a better more natural feeling . I have a KT controller with lcd3
3,994
The simple answer is no.
Have you set your KT to current control, which they call torque simulation?
8,752
Her we go again an electric bike that feel like a push bike !!!!
Ahmed55555
28
I can use the throttle without the pas but i just wanted a bottom bracket torque sensor instead of the cadence, i hear its possible with a CA3?
3,994
It's dead easy if you have a degree in computer science. Others might find it a bit more tricky, depending on how much research they want to do, their wiringskills and how much time they want to spend fine tuning the code in the settings. It's not a plug-and-play solution. All the CA does is convert the torque sensor throttle into a throttle signal.
