http://www.flickr.com/photos/extraenergy_ev/11999923336/sizes/l/in/set-72157639863235656/
shemozzle999 Esteemed Pedelecer Sep 28, 2009 2,826 686 Feb 18, 2014 #1 http://www.flickr.com/photos/extraenergy_ev/11999923336/sizes/l/in/set-72157639863235656/
T trex Esteemed Pedelecer May 15, 2011 7,703 2,671 Feb 18, 2014 #2 the specs look good, strong contender to Bosch reign you think? http://extraenergy.org/main.php?language=en&id=46919 M25 - Technical Data Weight: 3,99 kg (M25T), 3,95 kg (M25TC) Nominal Torque: 22N2m2Nm Max. Torque: 50Nm Nominal Output: 250W Maximal Output: 350W Efficiency: 75% Noise Level: < 65dB Coaster Brake: Yes AGT: Option http://www.elektrorad-magazin.de/nachrichten/neuheit-2014-tranzx-neue-mitte
D Deleted member 4366 Guest Feb 18, 2014 #3 Hmmmm! Is that the first Wankel electric motor? I did say ****el. not Waker with an n.
T trex Esteemed Pedelecer May 15, 2011 7,703 2,671 Feb 18, 2014 #4 d8veh, what do you think of the xiongda XD motor? I searched the forum for your posts but you are unusally quiet on this one.
D Deleted member 4366 Guest Feb 18, 2014 #5 I haven't got mine yet. It should arrive in about two weeks, then I'll let you know.
