Turnigy Wattmeter auxiliary power function
Scottyf
1,403
-1
If you wanted that could you just not wire it in before the switch for the battery?!?
If not you could change the switch in the negative position to actually create a live to keep the watt meter going.
Fordulike
3,802
1,538
Any idea of the standby current drain on one of these meters?
Can't imagine it to be much.
Scottyf
1,403
-1
I've left mine on while at work for about 12 hours in total and the volts dropped from 47.63 to 47.02v across a 10amp pack so I don't think it's that much.
It's more than some simple meters but it's by no means high. I wouldnt imagine more than a few watts for an hour If that.
Intact it's less than what I said as I leave my batteries running all sorts.
