Unlock Bosch Powerpack / Powertube e-bike battery | Canbus simulator
6,727
Bearing Man
115
149
Hampshire
www.ebikemotorcentre.com
That's great but I need to make a battery talk to a Bosch system, this seems to be to make a Bosch battery play with other systems. Great find though.
Reactions: soundwave
6,727
lets hope he can finally crack it as getting close and others are working on it ;)
Reactions: Bearing Man
6,727
they wont post to the uk but they use the bosch bms or have the can bus code to make them work but never seen inside one to check.
6,727
Torque-E-Cycles battery repair can bus specialists uk 01803 325945
6,727
it will discharge itself over time and if you leave it the bms will drain every cell to 0 v and brick the bms.
its called renewable tech when warranty ends you trow it in the bin and buy a new one.
also the new smart batts wont work on older motors :mad:
odys
Mar 4, 2025
I have a charger.
I want to use this battery on another bike, I will print the connector on a 3D printer and that's it.
but I cannot activate it so that it works constantly.
6,727
then just remove the bms and use a 3rd party one, there a pita to get open and not brake the clips tho!
