Upgraded Carrera Subway e bike
ArtNuevo
10
Hi,
I have just converted my Carrera Subway e-bike with a KT controller, LCD5 screen and 8 magnet PAS. All works fine i think I need to tweak a few setting on the P and C parameters but overall happy at the moment. My question is now I would like to change the crankset, the existing crankset housed the torque converter and weighs nearly 2kg, and is now not needed. Can I simply replace with another 42t crankset from online. Or is the alignment going to be different. Thanks in advance.
thelarkbox
1,659
514
oxon
I dunno.. but derailleur gears are Very forgiving especially when you consider many bikes use 3 chain rings 1 cm or so apart. so you should have in the region of circa 3 cm to play with..
So i would suggest its worth a punt especially if distance buying from a seller with a no quible returns policy..
since you will need an extraction tool (cheap under a fiver iirc) if you know anyone with a standard crankset on a bike invite them over or pop by with your bike n tools and check it out in advance.. or are you also replacing the bottom bracket too, and not just the crank.
Waspy
605
248
I replaced my triple crankset for a single chainring crankset from eBay.
You will want a 'narrow wide' chainring, it stops the chain falling off apparently.
Your chain line is the distance from the chainring to the centre of your frame, it should be about 50mm.
I also ordered some triple chain ring bolts and some 2mm chainring spacers.
I had to add 4mm of spacers between the spider and the chainring to bring the chainring inboard 4mm
I have links to all these things if you want.
8,804
What is the current crankset /chainring set up ?
1X, 2X or 3X ?
ArtNuevo
10
Thanks for the advice. With existing chain ring 50mm to centre as you state. Tried chainring from my other Carrera (newer version with BB sensor) and it is 55mm so yes there is a difference.
ArtNuevo
10
1X, 2X or 3X ?
Thanks for response. Current front chainring is a single 42t. 9 speed at the rear. Have taken chainring to 3 shops and they all want the bike in to look at. I did assume that it would be slightly simpler than they were all suggesting.
4,102
Hi,
Yes you can. I'm pretty sure that the bottom bracket is standard 68mm Shimano/BSA type. You can use a much lighter one. I recommend 44T to 48T, maybe 42 if you like pedalling fast or you're a big guy and don't want to go fast.
Waspy
605
248
Some pictures of your BB/ crankset / chainring would help this thread :)
thelarkbox
1,659
514
oxon
not much visible taper to the square keys so with spacers you should be able to position a replacement where you want it
ArtNuevo
10
Thanks for reply where do you put the spacers. Am I right in thinking you would by a crankset with replaceable chain ring ie 130 bcd then put spacers in the chain ring. Presumably not spacers on the square drive.
ArtNuevo
10
Hi, Waspy
Yes links would be great.
thelarkbox
1,659
514
oxon
tbh first i heard about crank spacers was in @Waspy 's post above, a more standard cycle would have a round 'axle' with square tapers onto which you mount the crankset
8,804
If you buy Shimano Hollowtech ll BB's then one can use spacers in between the BB shell & the bearing cups.
Waspy
605
248
Once you have it set up you can play around with chainring sizes, you can buy them separately.
I started off with 34 tooth, currently on 42 tooth. The bigger the chain ring the less you will spin out in top gear.
ArtNuevo
10
Thanks for the advice and explanation. I understand it better now. Think I will purchase a good quality second hand crankset and then as you said I can change chainrings and spacers to get it set up right. It makes sense now.
Waspy
605
248
Don't forget, without a front derailleur you will need a 'Narrow Wide' chainring or your chain may fall off.
Currently you have a guard on your chain ring to keep it in place.
Alternatively you can fit one of these:
