Help! Urbanmover UM44 cuts out
davedor53
Jan 4, 2022
Hi everyone.
Newbie member, first posting.
Bought a UM44 Urbanmover (probably 10 years old, bit battered) recently for £300, and shortly after trouble free period the pedal assist cut out despite battery being fully charged. Stopped, switched off and on again and it went again, but any load put on it results in it repeatedly cutting out. All connections seem to be ok. Urbanmover tell me it's most likely old battery and they can refurb it for £320. Bit reluctant to do this as it may not solve the issue. Half a mind to sell it as it is for parts but would really like to solve this problem. Have any other members had similar issues with UM44 cutting out and what solutions they tried. Many thanks in advance. Dave
2,841
It does sound as if battery is the most likely culprit, especially given its age. £320 seems expensive for 26v, 9ah.
If you can swap it yourself they advertise this for £257:
I don't know if you can swap it for a generic 25v one (or more likely 24v).
8,796
Knackered battery or one out of balance, what is the voltage reading fully charged ?
It is typical of an old battery to have the voltage collapse or sag horribly even when fully charged, when this occurs it is usually a sign of aging and ready for recycling.
10 years is a good life span for ebike battery.
davedor53
Jan 4, 2022
Many thanks sjpt, that suggestion would seem the best solution and cheaper too. cheers
davedor53
Jan 4, 2022
Thaks for the reply - once connected to the charger for +12 hours battery reads fully charged - sorry no voltage reading, then just gives up on slightest incline. most likely issue is ageing battery and time to recycle. thanks for your time!
2,841
Yes. A dead battery will record full voltage after charge, it's just as soon as you try to draw any current from it it dies. So a voltage reading probably on the charged but unloaded battery probably wouldn't help.
8,796
A voltage reading is the only sure way of knowing if a battery is fully charged, though likely the voltage is simply collapsing with any decent load. Led charge lights are only an indication.
