Deleted member 17881
Hello,
Here are the motors specification:
Velineon 3500 Specifications:
3500kv
Type.....Sensorless brushless
RPM/volt..... 3500 (10-turn)
Magnet type...Ultra High-Temperature Sintered Neodymium
Connection type ...TRX 3.5mm bullet connectors
Wire size.....12-gauge Maxx® Cable
Current Ratings...65A constant; 100A peak/burst
Max RPM...50,000
Diameter.....36mm (1.42”) (540 size)
Length....55mm (2.165”)
Weight...262g (9.24oz)
Speed controller specification:
VXL-3s WATERPROOF ESC SPECIFICATIONS
Input Voltage: NiCad/NiMH 4-9 Cells (4.8 to 10.8 Volts DC);
LiPo 2-3 Cells (7.4 to 11.1 Volts DC)
Case Size: 39mmW x 55mmD x 33mmH
Weight: 90 grams
Motor Limit (Brushed/Brushless): No motor limit
On Resistance Forward: 0.00075 Ohms
On Resistance Reverse: 0.00075 Ohms
Peak Current - Forward: 320A
Peak Current - Reverse: 320A
Braking Current: 320A
Continuous Current: 200A
BEC Voltage: 6.0 V
BEC Current: 2.5A (with 6-cell NiMH)
Power Wire: 12-Gauge Maxx® Cable
Input Harness Wire: 26 Gauge / 100mm
Transistor Type: MOSFET
Low Voltage Detection: 2-Stage indicators, switchable (on or off)
Thermal Protection: 2-Stage thermal shutdown
Profile selection: Sport Mode:
100% FWD, 100% BRAKES, 100% REV
Race Mode:
100% FWD, 100% BRAKES, NO REV
Training Mode:**
50% FWD, 100% BRAKES, 50% REV
Single-Button Setup: Yes, Traxxas EZ-Set®
Battery Input Connector : Traxxas High-Current Connector
Motor Types (Autodetect): Brushed, brushless, sensored brushless
Ports: RX Input, motor sensor, auxiliary fan
Website for speed controller: https://traxxas.com/products/parts/escs/vxl3s. Website for motor: https://traxxas.com/sites/default/files/3351-INST-KC1682 Velineon 3500_ML_120813.pdf
What do you think about using this motor, speed controller for a mountain bike to be a electric bike?
Thanks for all your help
3500kv
Max RPM...50,000
Weight: 90 grams
BEC Voltage: 6.0 V
Race Mode:
Training Mode:**
