Does anyone know of a decent battery charge and discharge device that you can fit between a eBike battery (36V in my case) and a charger or load.
I wanted to test the capacity of the batteries for eBrompton and have tried one of these;
But it just does not work properly, the high voltage cutoff does not work and it fairly easily gets into a state whereby although there is 2A of charge current flowing, it displays 00.00A and you have to reset and calibrate it. But its cheap, £19, and I guess it could be a knock off of the real thing from Drok.
Any suggestions for an alternative that has display of voltage, current, Ahr, maybe time, and with working high voltage and low voltage cutoffs ?
