whats the best method of carrying a spare dolphin battery please?
footpump
713
75
76
was trying to get some rough idea of range on new dolphin battery last week.
as my older dolphin 13.4ah and the new one share the same mounting rail it is the first time
I would be able to carry a spare or swop over batteries
I have a rear rack and 2 lidl paniers but these would not be suitable to carry 3k battery,
did not fancy the idea of using a rucksack in case the battery fell out of the bottom
or the discomfort of a battery bouncing about on ones back.
so in the end did not carry the spare.
so any suggestions for carrying a spare.
footpump
713
75
76
and I thought my handlebars were cluttered?
leigh whats the black thing to the right of handlebar stem.
I can just see lcd3/dolphin and nxt seatpost amoungst the stuff
Gubbins
when I had a spare bosch battery I bought a cheap top bag to fit on the rear rack. I googled around until I found one with suitable internal dimensions to take the battery and the polistyrene end peices that came in the batteries shipping box. This worked exceptionally well as it was out of the way and snuggly secured secured against bumpy terain.
Something like this..
https://www.amazon.co.uk/BestFire-Mountain-Waterproof-Accessories-Shoulder/dp/B01FUFRTNA/ref=sr_1_16?s=sports&ie=UTF8&qid=1516785556&sr=1-16&keywords=bike+saddle+bag
RobF
4,732
2,312
It is a dead weight, but the Aldi panniers ought to be OK with 3kg.
They are probably rated to carry 10kg.
On the rare occasions I carry another battery I go the Gubbins route and use a trunk bag.
Quite a snug fit lengthways in mine, but that doesn't matter.
Gubbins
I tried the aldi panniers .. The weight wasn't really a problem until I went over a bump or two.. The shock of, in my case heavy camera gear, going weightless and then dropping back down was enough to eventually break the mounts, whereas with a rack top bag the shock is born by the rack itself and if it's a snug fit with no movement there is less chance of damage.
I took my battery around the bike shops to try some bags for size and I think I actually bought mine fron halfords.
Reactions: LeighPing
RobF
4,732
2,312
I have carried a battery in my twenty
quid Edinburgh Bicycles panniers with no problems.
They might be a bit sturdier than the Aldi ones.
And I try to avoid numps, kerbs, and the like.
I've also carried a battery in my smaller and even cheaper Halfords panniers.
That wasn't quite so successful, the stitching started to come apart and the bag flopped against the tyre, so I don't do that any longer.
Benjahmin
2,770
1,821
71
West Wales
I use the pannier you can see in the avatar. However I do put a bungee round the pannier to stop the weight slopping around. I can feel the off centre weight but it's not a problem on road.
  • Useful
8,838
A hard pack battery on the down tube then a couple of soft packs in a rear top bag set up in parallel, using the zip down panniers for tools and other bits and bobs. The weight is carried better on top then on the sides.
Soft packs about £50 cheaper for same 10s5p config and of late a wider choice of cells being used with 3500mah MJ1 & 35E.
  • Useful
If you have a rear carrier, bolt the spare battery's receiver to it, then you can lock the spare battery there and swap them over when you need to.
footpump
713
75
76
thanks all have a tool bag, and a rack bag I forgot I had which I could use to carry battery and hold secure with bungee straps.
as I have a spare dolphin battery mount I could use the method suggested by d8veh this way the battery is not flapping about.
Kenny
383
111
West of Scotland
+1 for the Vaude silkroad.
The larger size with the drop down side pockets gives you plenty of storage, even with a bulky battery loaded in the main compartment.
egroover
1,101
656
58
UK
Yep, I can confirm that the one in the link above is the one I ordered and has the drop down side pockets, even though the picture shows it without. Here's it on my bike
Reactions: Kenny
egroover
1,101
656
58
UK
