Where are the controller settings stored?
Cisco-man
299
75
Hi.
I’m wondering where the settings are typically held when you set them on the display. I would expect them to be stored in the actual controller, but it’s possible to have them stored in the display unit I guess. Can someone tell me - thanks!
3,976
Hi.
It's all explained here:
Cisco-man
299
75
So my expectation is, that when I plug a virgin C500 display into my Lishui (Swytch) controller, that current settings won’t be altered by the C500. I shall give it a go…
3,976
That's not necessarily true. It depends on many factors. Best is to try it, then you know.
That link above is to give an idea of how it all works in the context of a KT controller. Other controllers have similar communications and work under the same principles, but might be different in what they do with their parameters.
Cisco-man
299
75
Agreed. I’ve checked the plug is the same, and I can see no reason why they would run a different comms protocol - which I believe they call KM5S. I don’t think I shall blow anything. There might even be absolutely no advantage in the C500, but I’m hoping I’ll get something out of it.
3,976
We all learn when people try things.
Reactions: Cisco-man
