Where to buy smart charger Luna Charger 52V from
3,994
Get yourself a 60v 5A lab power supply. They're cheaper and most likely have the same components/module in them. Gophert make a nice one that's practically the same.
3,994
There's a dial to set the voltage and an LED display to show what you've set it to. It's the same for the current. You'd hsve to have a few braincells missing to get it wrong. You can use it to charge anything.
3,994
Yes, it's CC, CV, just like any charger, i.e. it gives the current you set until it gets close to the voltage, then it ramps the current down and will aim to keep the set voltage constant after that.
jkekoni
Mar 1, 2019
Lab power supply does not disconnect charger, when current drops. eBike changer does.
3,994
Where did you get that from? I have seen some ebike chargers that latch off, but most are CC-CV and hold maximum charging voltage as long as they're connected. That's important for balancing.
