Where to purchase in the uk 2 pin female battery lead
it is i footpump
102
23
76
Hi all today my ebike suddenly stopped giving any assistance, lcd3 display showing nothing.
Could not see anything obvious so bike and myself into taxi and home.
connecting up the battery,and trying another spare one,it kept blowing fuses, The 2 pin battery to controller lead is shorting out,, so would like tp purchase another but can only find ones in the us,which makes it expensive.
any one have a link in the uk or ali express ? Photo is of kt. Battery lead 2 pin female
8,790
Is it a case that the Black two pin connection is being connected incorrectly polarity wise hence the fuse blowing ?
If the Black connector is for the battery either cut it and hard wire (solder the wires direct) leaving just the XT as a fly lead form said battery.
Show us the actual battery connection and the actual controller connection.
3,994
Dit you test the lead to confirm the short, or dos it blow the fuse as soon as you connect it on the one end only?
it is i footpump
102
23
76
Thanks all i assumed the (short) was in the lead tx60 to female 2 pin to controller lead? As the outer plastic sheath has split in 2 places.
However doing a (continuity test ) the lead seems ok.
I took the top of the controller off ,doing a test for continuity by testing the black/red battery leads where it is soldered to the circuit board ,its seems there was a short ?
But i cannot get the pcb board out off the case, all screws removed.
i have another controller which i believe is ok ,awaiting delivery of some more red/ black cable.
Have not as yet tried to reinstall components
