Wiring - help needed!!
parkeretal
Feb 27, 2009
I'll try this again - I don't know where my last post ended up:confused: .
I have just purchased a cheap kit. So cheap it did not even come with a wiring diagram! Unsurprisingly, I've not had much success getting any info from the supplier. I think that it may have come originally from a company called VPower but I can't get onto their HK website.
This is a photo of the controller:-
New Page 1
Most of it is OK, I just have 2 questions:-
1. I assume that the heavy red and black wires in the white connector block on the controller are + (or switched positive) and negative from the battery, but what is the thin red wire?
2. The supplier said that the green/yellow single wire is for the brake switch, but how is the circuit completed? Through the normally open brake switches to ground on the controller body or to negative?
Any help would be appreciated,
Ian
fishingpaul
874
86
I have had two different types of controllers, and in both cases both the thick and thin red wires had to be connected to the positive battery lead,personally i did not bother with the brake wiring so i cant help there.
Herb
106
Link to Frank's Website
QUOTE
Bafang Engine:
Power supply:
Red must be connected to the positive (recommendation: backup 20A insert), black to the negative pole and the thin red wire is also connected to 36Volt Plus. If you are in the thin red wire to install a switch you can turn the controller () standby circuit. However, we recommend a main power switch, so you do not always have to disconnect the battery (engine pulls) of electricity even when not in use.
QUOTE
The above is taken from Frank's website and is the method I have used on my Bafang motor/controler connections.
Caution - You would have to be certain this applies to your controler.
Worth a look at the pages to see if the controllers /connections are similar ?
Herb
Herb
106
Ref above
The page is in German . Google will translate for you
Herb
parkeretal
Feb 27, 2009
Thank you
Thanks guys.
It appears to be working well in the garage. I just need to get the wiring tidy and weatherproof.
Ian
