Woosh Rambletta
overlander
532
42
Hi everyone,
Been putting decent miles onto the woosh Rambletta. It’s been out in rain, snow and hail. It’s time for some maintenance as when pushing hard on the pedals there is a clunk. Checked the cranks and folding mechanism most likely bottom bracket needs tightened. What bottom bracket is on this bike and what socket will fit it ? Thanks
17,342
From memory it's a Neco square taper bottom bracket. It's compatible with standard shimano square taper bottom brackets.
If you need a little help, email support@wooshbikes.co.uk - Andy will help you sort it.
overlander
532
42
Thanks for that, I’ve got the socket to tighten that bracket. What is the stock situation with the Rambletta and the Gran Camino. Thanks
17,342
shipment is due end of March but there is a build backlog. Do give Hatti a call.
Also, there are a couple of Ramblettas on the second hand page:
https://wooshbikes.co.uk/?secondhand
