Y Splitter Cable for cycle light
Gringo
1,352
843
Northampton
OK so I had 10 minuets to kill (waiting for my fish'n'chips):)
A bit of googling tells me your lights/battery uses a standard 5.5x2.1mm dc connector.
So I then looked on the bay for a "Y" lead that uses those sizes.
I came up with this :cool:
http://www.ebay.co.uk/itm/5-5mm-x-2-1mm-DC-2-x-Male-to-1-x-Female-2-Way-Y-Splitter-Power-Cable-for-CCTV-/301143434481?pt=UK_CCTV&hash=item461d8c24f1
You'll have to confirm those connector sizes cos I only looked at one old forum discussion.
May the brightness of knowledge light your way through the darkness of ignorance;)
Gringo
1,352
843
Northampton
The item In your link dose not state connector sizes but another battery from the same seller has a DC5.5mm x 2.5mm
That's different to the lead I spotted.
You need to measure your connector, assuming your outer dia is 5.5mm you will need to measure the size of the pin in the middle 2.?mm
Are you near a Maplins ? If you are then pop in with your bits:rolleyes: And try some of there connectors. At least you'll know what size you using, at best you could buy the bits and make your own Y ;)
http://www.maplin.co.uk/search?text=5.5mm dc&page=1&sort=&productsPerPage=#
Reactions: mountainsport
mountainsport
1,419
298
Lovely Gringo, I did have Maplins in mind initially and there is a store about three miles away from where I live, will drive up there over the weekend. Thanks for your time anyway :cool:.
Was your batter any good?:)
MS.
Gringo
1,352
843
Northampton
Mostly good but a bit soggy on the bottom !
After work took me up north some time back I've developed a strange liking for gravy,
Anywho
There's a whole array of similar sized connectors, even when you've matched the outside dia the middle pin size can vary. Miss matched 5.5mm connectors can still work (sometimes) a 2.1 pin will fit in a 2.5 hole and work just fine but push as hard as you like but you'll not get a 2.5 pin into a2.1mm hole.
Happy shopping ;)
