Yamaha PW-SE will not power on
Döner
Dec 9, 2020
Hello,
I have a bike with Yamaha PW-SE motor. Motor will not power on. Display flashes all segments as long as power button is pressed.
Like this 39665
So far what I have tried:
-different battery and cleaned connectors
-measured that all cables are good
-opened motor and checked all connections
Any ideas what might cause this issue? Didn't find any hints with Google.
Edit: When pressing power button long enough, it flashes er and 88 in speed section and shows er 12 in trip section. When power button is released, display will shut down.
jmlflorencio
27
Do you have access to the bike documentation?
Those seem to be error codes of some sort (error 88 and error 12).
3,986
Döner
Dec 9, 2020
I have tried different display unit and cable, did not help. Looks like it is in motor side.
Are you able to buy controller board separately? How to diagnose that?
6,337
you cant buy the controllers only option would be a new motor or https://www.performancelinebearings.com/ might be able to help out but it is a long shot tbh.
oramet
Apr 4, 2022
Hello,
I have exactly the same problem as Mr Doner.
Have you find an issue ?
6,337
6,337
id send it in as might also need some bearings changed if water has got in and also shorted the board.
