your views on this enerpac 36v 13ah battery pack?
footpump
713
75
76
8,788
footpump
713
75
76
thanks all
not sure how these compare with Samsung 30q but have ordered the 36v 13.8
I wish I had a 6 pack
8,788
thanks all
Swings and roundabouts it all depends on the terrain and speed for your riding. The max amp load per cell will be about 3.75a on max pas and on lower pas - 2a loading.
On flat to moderate terrain then MJ1 will give probably 10% + more range and 3hrs of riding or more.
For hilly terrain 30Q would hold up voltage higher so less sag and range would be even out between the two.
The more cells in parallel the less stress and amp draw is required of each cell so range would be greater as is the battery capacity, the flip side is a heavier battery.
