Zhipu controller wiring
Golden2000
24
I have this controller with cable red p+ green 5v black gnd , anyone know why this cable ?
4,004
Do you have the control panel that goes with it? That will give you a clue to whether that's a throttle or PAS connector.
Alternatively, if you put power on the battery wires and connect the motor, then connect the control panel and switch it on if you have it, or join the orange to the red wire in the control panel connector if you don't have it. Now, if you bridge the red to the green wire in that three pin connector and the motor goes full speed, it's for a throttle. If the nmotor doesn't go, tap those wires together as frequenly as you can. if that makes the motor go, it's for a normal pedal sensor.
Orange and white are battery voltage that switches on when you switch on the control panel -for lights or whatever you want. Red and black is also battery voltage. it stays on as long as the battery is connected and switched on. Black and white is probably the brake connector. The rest are obvious.
Golden2000
24
the problem I don’t have the lcd and i am looking to run the controller without it just connect throttle, but the problem the throttle pins on board not solder any thing on it, i try to soldering wire on this pins but the controller not work
4,004
Join the orange and red wires and test that connector like I explained above. Be careful not to let the red wire or your bridge touch any of the other wires except orange.
Golden2000
24
I already connected vcc with p+ and it’s and i test it by multimeter it’s give me 5v on many pins but it’s not work , it’s seems missed something to wire
