Kt3 LCD swap with kt2 LCD
Do you want to sell the kt3 has it the waterproof fitting Sent from my Lenovo TB3-710F using Tapatalk
Bike change / shed clearance/ motors and bits
No private message Sent from my Lenovo TB3-710F using Tapatalk
Yes I'll have it please Sent from my Lenovo TB3-710F using Tapatalk
Yes I have it thanks have you got email or phone Sent from my Lenovo TB3-710F using Tapatalk
1 x mxus 250w 36v front motor in 26 inch rim. Have you still got it and how much Sent from my Lenovo TB3-710F using Tapatalk
Ebco ucl60 PCB controller ifrb3307 fail
The controller and bike is now fixed the problem was caused by fuse holder on battery the lugs which were carrying car type fuse were arcing and the fuse was not pushed into lugs so have had lugs filed down and bike goes better with the 4110 thank you Sent from my Lenovo TB3-710F using Tapatalk
Tranzx 36volt battery
Hi seeing this battery uses canbus can I use it with a front wheel hub kit which will be cheaper than fixing the controller Sent from my Lenovo TB3-710F using Tapatalk
The controller has not lasted long circuit board part not well made Sent from my Lenovo TB3-710F using Tapatalk
Does anyone do controller PCB repair someone has replaced the misfits 4110 bike engine worked for a short time the display still works the parts operated by canbus any way of getting a cheap controller ebco want 199 for anew controller and75 for programming the PCB the tranzx controller does not seem worth it it has lasted long Sent from my Lenovo TB3-710F using Tapatalk
I found it on internet Sent from my Lenovo TB3-710F using Tapatalk
Had some one fit new 4110 and he also a diode on motor wires and battery leads now the display works but no motor so is it just a case of removing the diode on motor wires now if anybody has got any software for the bike I would appreciate it thanks Sent from my Lenovo TB3-710F using Tapatalk
OK thanks Sent from my Lenovo TB3-710F using Tapatalk
Is there any way of putting better moisfit so they don't fail again please the bike was brought out of warranty two of the ifrb 3307 have failed previously Sent from my Lenovo TB3-710F using Tapatalk N type mosfit
nigel610
Joined
Last visited
