HansF
  1. Thank you d8veh, I'm fine now! But if I will build my second, I shall remember to ask you if needed.
  2. Hi, I am a new member. I live in Norway, my postal code is 1604 Fredrikstad.
  3. Can you learn me more about the map function? Tried, but could not find it in my account settings.
  4. Status spring 2016. All works well besides the power cutoffs:(. tbc...
  5. Headlight and extras. tbc... List of stuff: LM2596HV DC-DC Converter 4.5-60V Step-Down Module, eBay user: snakewang2005 Red LED Rear Light 3 modes Waterproof Tail Lamp, eBay user: fdhouse
  6. Controller S06S frankenstein. tbc... Stuff: IRFB3077 TO220 High Efficiency Synchronous, eBau user: hkutsource
  7. Bottle battery 13s2p 54v build. tbc...
  8. Bottle battery 10s1p 36v test build. tbc... Studied, searched and read about cable for powering ebikne, type of 18650 cells, to use a bms or not. List of stuff: Samsung INR18650-25R 3.6V 2500mAh from www.fasttech.com. Solder from ebay. Nickel tape from ebay 10 Cells 36V 40A BMS, eBay Turnigy 14AWG Silicone Wire (Red and Black), www.hobbyking.com Turnigy 20AWG Silicone Wire (Red and Black), www.hobbyking.com Charger, ebay. (Charger, bmsbattery. Has an earthing error) EC2 connectors for charging, ebay XT-60 connectors for power, ebay Waterproof junction box, eBay user: mgokay Silicon wires sch10 and sch14, hobbyking Put together a 10s1p system. Leaded all battery ends. Cut ni tape, and connected cells and bms. Mixed up the bms charger connections, and smoked the first bms:(. Orderd a second, squached in the mail, nice ebay seller sent me the third at no cost:). Marked all wires with numbers, no errors. But a short at the end of the assembly scared me, blue flash and a crack sound, and the ni tape spat all over. I use glass magnifier during soldering, lucky after all. Even more precasion, and fitted the 10s pack inside the bottle with no more incidents.
  9. Motor and front wheel build. tbc... List of stuff: First new ø160 disc brake had wrong bolt hole diameter. next bought from eBay. New rim, xxx, bought at local bike shop. Spokes bought from bmsbattery together with stuff listed above did not fit, to long, and the xxx to thick. New set of spokes from eBay (venturavorld). Disc brake mechanical caliper Brake wire OLd rim had 32 spokes, motor was for 36 spokes. Helpful Tool: Spoke Calculator and Wheel Building 5th edition by Roger Musson. Fitted new wheel on bike. I wanted two torque arms, extra sequrity against damage on the aluminium fork. Fork had a washer recess with to small diameter for the supplied stainless antirotating washer. I turned two new brass washers and put them under the ss washers.
  10. As I wrote in the "about myself" post: I want to share some of my experiences back to this comunity, that has helped me alot! I plan to add some posts with the progress of my ebike build. Bike: Nakamura offroad bike w/disc brakes. List of components (bought from bmsbattery Oct. 2014): Q100 36V front drive motor S06S 250w torque simulation sine wave controller S_LCD3 lcd panel Eight pole PAS Speed sensor Bottle battery case (empty) for 18650 cells Torque arm Brake grip
  11. Hi First, thanks to all the information in this forum, and the people that has contributed! I have now my own ebike, aka pedelec. . ., after a two year read/order/build/try/read/fix/ride period. I live in Norway, not far from Oslo. My motivation for joining is to give something back to the users of this forum. Br Hans Fredrik
