LittleMo
  1. The rack that David of AMPS supplied (bolts on top of bike rack) works well with my Ortlieb panniers - thanks David.
  2. It's a great bike - many thanks. I do find the battery indicator always drops a bar on my way up a hill to work (nearly half a mile that I used to crawl up in my bottom gear!), but then seems to recover afterwards! It has brought me back to the speed I used to cycle at, which is great. The rack works fine too. Many thanks, Little Mo (aka Mara)
  3. Hi David. I thought Liam had asked for the pannier extension? I definitely want it, as the bike is not my 1st choice without it. Thanks, Mara
  4. Thanks. If that's the one I buy then would be through the ebike centre in Leicester as they have put a lot into letting me try out the bikes. How would I go about it? I sometimes use 2 panniers. Do I need 2 adapters? M
  5. Hi David. Wondering if it is possible to attach my Ortlieb classic panniers to the rack - doesn't look like there's enough room. Am going to take one with me to try out anyway. Thanks.
  6. The Wisper has a throttle and cadence mode as well as torque, which means that I can get the bike to move with little effort if my legs are failing me. The Ferber just has the torque mode, though it is a nice bike. Thanks for photo - too small for me to tell which bike it is!
  7. I'm trying to decide between these two bikes - any pros and cons you can offer? I have ridden both, but at separate places, so hard to decide which I preferred to ride,though I know I liked both. I suspect that the throttle and cadence option on the wisper may be the deciding factor because of problems I have with my ankles.
  8. I like the wisper 705 bike, but it doesn't look as if you could fit a pannier on the rack. I have Ortlieb classic rear panniers. The review of the 905 on this site says that the author got their Ortlieb panniers to attach - are they the same type or were adjustments needed? The shop I went to tried suggested the sort that fit over the top, but I need to fit a lot in for work or shopping trips, to be able to carry using the shoulder straps on the panniers, and to be able to attach and detach them quickly as I often need to remove them when I stop. Does anyone know? Thanks.
