Rob-KTM
Everything posted by Rob-KTM
  1. Thanks for this Dario, I bought my bike from JE James too.. so will give them a nudge for the same solution :-) Keep looking at other bikes!! as it's the UK and I use my bike most days... or I did till I got this Giant!
  2. If you look at the buttons that control power etc, you will see a wire coming out to a connector on the break line, this is the one to unplug... if the bike starts to go a bit nuts like mine, it might help you get home as the motor will work just fine in its last settings.. and turn off after 5 mins of no use. See photo from when mine failed at a bottom of a rather nasty hill.
  3. Woosh, I understand your products have a IP rating... but really this has nothing to do with the Giant products we are talking about in these posts and is confusing matters. The Giant display and buttons clearly have no water seals or IP rating as any rain makes them fail!.
  4. I have this same problem with my Giant, the solution is unplug the Evo display from the control buttons... the bike will then power down after 5 mins if not ridden.. After about a week my buttons start working again, happens if used in the rain!! Never had any problems with my Yamaha powered Haibike!, the original Yamaha buttons and display are all sealed at every contact point. Shame as I thought the Giant was going to be a nice upgrade with there custom software.
  5. I've got the same problems with foggy display, but my Giant will go into Walk home mode after a min by itself and stop responding to control inputs, also will not turn off, just keeps rebooting if you turn it off. Removing the battery is the only solution to stop it!
  6. I will send you my email address now, as a PM. Rob
  7. Hi, I'm very tempted by this bike for my wife.... Is it still for sale? Rob
  8. Been looking at getting a Bosch performance cx powered bike, I've found a second hand one... But it has done 4500 road miles in 18 months, the crank bearings seem fine for play. So how long do you think these motors last? Is 4500 miles getting to the end of its life? Thanks Rob
  9. Hi, Is this bike still for sale? Rob
  10. Thanks Peter, that is a great idea.. Did not even know they had a range of Bosch powered bikes now.
  11. Hi, Has anyone had any luck getting a refund? I ask as we have two impulse 2 powered Kalkhoff bikes, both of which are now failing again.. This will be their second motor replacement in less than 18 months!! The bikes where bought from 50cycles. We live in Devon so miles from 50cycles to keep taking the bikes back!! also the main issue is breaking down as it is rather hilly around here so would be completely stuck! Rob
