thomas_d.b
  1. what you might really need is a 10 kilo-ohms pulldown-resistor between the 0 volt ground and the signal wire of the hall sensor , cause your signal wire is floating at 5 volt and overrules the output of the sensor itselve, wich is lower. this fixed my goldenmotor kit to be able to support the pedal assist
