Wanderer
  1. Also any ideas about the back brake(back brake karasawa 90 drum brake) if it’s possible the change the lining or does it need a new part thanks
  2. Hi I’ve been in touch with sportshq sent them a picture of the wiring and they say they have them in stock(£15) and they are sending me one. Will let you know how I get on
  3. This is the end of the throttle cable Hi, I’ve attached a pic of the throttle end it has 3 connectors
  4. Thanks again will do think it’s the throttle wiring in the pic
  5. Hi thanks for that very informative reply really appreciate it, I suppose I could buy a similar product on eBay
  6. Hi I have a cyclamatic 24v bike but I’m using a 36v battery with no problems i had an accident on it a while ago which broke a few things. I have had the motor repaired and it runs ok but the shimano x7 gear changer and the throttle were also broken so was looking for replacements also the back brake karasawa 90 drum brake is not good either, is it possible to renew the lining or is it a new unit? A lot of questions I know but if anyone can help I would be extremely grateful Best regards Rob
  7. Hi it’s me again after a few weeks of the bike working without using the throttle it’s stopped working, my question is if I take the throttle off although would it still work through the pedals? Regards
  8. Hi it’s me again after a few weeks of the bike working without using the throttle it’s stopped working, my question is if I take the throttle off although would it still work through the pedals? Regards
  9. Ok thanks cyclamatic say that they may have one but it’s £30 compared to £10
  10. Tbh would rather the wires fitted and the twist grip worked not too bothered about the battery lights So that probably means the 24v?
  11. Looking again maybe wheeliepetes 1st suggestion is best does the voltage matter my bike is made for a 24v but I have been using a 36v battery for over a year with no problems
  12. Thanks everyone I will go with the second one from wheeliepete suggestion from AliExpress it looks identical
  13. Well after many tries think the problem is with the throttle on the handlebars took it apart and the little magnet sensor dropped off and there was a wire floating around not sure from where. The upshot is that when I put it back together the throttle didn’t work but the pedal sensors did so at least I can use the bike. Anyone any ideas on where I could buy a new throttle? Looks like there are 6 wires.
  14. Hi tried the brake connectors but no joy, I don’t think the fault is down in the wiring loom cleaned and tightened up the main wires. The handlebar indicator power light case gets a bit warm but I don’t think that would affect as it still won’t work while peddling. Will have a look though. Could the fuses make a difference or would they just blow and need replacing? Haven’t taken the top off the battery as was a bit concerned I could get it back on However if nothing else works will have a look Regards
  15. Ok will try that which wires are they
