bobp
  1. this shows the process. Sent from my iPad using Tapatalk
  2. I,m sure I saw a video on utube showing you how to do this. Sent from my iPad using Tapatalk
  3. Yeah it also has a pre drilled hole in the seat tube to route a hose on the outside of the but I just ran it straight through and up the front down tube with the wiring harness . I've the full suspension sDuro AllMtn. Sent from my iPad using Tapatalk
  4. Hi NismO I dropped the motor by removing three of the mounting bolts and swinging it down . There was enough room above the motor to route it down the seat tube and up the front tube emerging from the gear/brake outlet. Obviously I had to remove the actuator and bleed the system on reassembly. Sent from my iPad using Tapatalk
  5. Most bike parks like Whinlatter in the Lake District hire out ebikes. A great way to test before you unload your wallet. I've never regretted it for a moment. Sent from my iPad using Tapatalk
  6. I use a tow bar mounted Pendle rack to carry two ebikes. No problems . Really secure. Sent from my iPad using Tapatalk
  7. Tow bar mounted Pendle rack carries my two haibikes no probs. Couple of hundred quid to secure seven grand worth of bikes is what I call value for money. Sent from my iPad using Tapatalk
  8. Sick of my sDuro dongle requiring a contact clean up. I'm considering a badass box has anyone experience of these units. Sent from my iPad using Tapatalk
  9. Aching legs means better legs in the long run. Keep it up. Sent from my iPad using Tapatalk
  10. You've got me feeling guilty now. Are my false teeth cheating? Sent from my iPad using Tapatalk
  11. My ebike gets me to places I would never see at my age (64) . It's renewed my interest in mountain biking and any assisted miles are still better than no miles. Sent from my iPad using Tapatalk
  12. Cheers Chris. Still trying to convince the wife but no go. Although me bike buddy had one ride on mine and ordered one lol.
  13. Installed a RS stealth on my Haibike ran internally no probs. Be sure to size correctly the, 100mm stealth is the only one that would fully insert on my frame. The others left the dropped seat too high for my short 30" inside leg.
