GeniusBike
  1. Struggling to find somewhere in the UK that sells Bosch replacement batteries. Any recommendations of shops with stock appreciated.
  2. I've just taken the battery and bike to a bosch service centre. The charger is working and charged another battery they had in the shop. They can run a diagnostic on the battery but only when it's attached to the bike. I'll be taking it back on Monday. Not looking good for a battery that's done less than 500k.
  3. I'm in East Manchester near the Etihad stadium. I've just run a multi-meter on the charger and it's out-put voltage is zero indicating the it's broken.
  4. I swapped over the fuses this morning. Didn't have any effect. Indicator lights are on but the battery doesn't seem to be charging. :-(
  5. Hi Everyone, 3 weeks into E-biking and I think I have an issue with my battery charging. Can you help me sense check if there is an issue? Battery = Bosch Powerpack 500 I plugged it in this morning to charge with the standard Bosch charger. The battery indicator light's on the battery illuminate however ...... on previous charging im sure the lights would flash, they are currently solid at 3 bars and after a few hours charging are not budging. Can anyone confirm: Battery indicator lights should flash to indicate charging? How I'd check if the charger is faulty (other than testing on another battery)? Any help would be appreciated, even if it's just to tell me I'm thick :-)
