Woosh RIO fb Throttle
Thanks Mike, yes a custom build is the way to go I think, rather than hack the FB. I've not tried shopping from Aliexpress, I must give it a go. I actually bought my Schwalbe Space tyres from Bikester, I've just had a look and they appear to be out of stock. I paid £26.97 for two inc delivery via DPD. They look good on the bike and ride well. I used the existing tubes. The tyre spec is:- SCHWALBE Space Wired-on Tire 26" K-Guard SBC black (Wheel width 60-559 | 26x2.35")
Yes, I was aware of that, thanks. But not as good as the method I have recently discovered. The Bike accelerates really well and keeps on going without pedalling. There should be a way of enabling it, making it much easier to use.
EFNEO GTRO
Thanks Mr. Woosh, have you fitted one of these? I'm thinking the twist grip would be easier to fit than the trigger type. Assuming that the handle bar is the required diameter. Although expensive, It looks like a worthwhile addition. Any advice would be welcome.
EFNEO GTRO
Sorry forgot to post the link, Doh! thanks for letting me know. https://road.cc/content/review/227796-efneo-gtro-3-speed-front-gearbox
EFNEO GTRO
Anyone got one of these? Thinking about the problems fitting one to a Woosh Rio Fat Bike. Only problem I can see so far is the crank sensor and where to locate the gear changer.
I've spent all day looking for a KT HL Controller. And have found one in China that might fit. Nothing in the UK. I guess the country isn't ready for EBikes yet. So giving up. I'll probably buy a rear wheel kit complete with KT Controller and build my own bike. All I wanted to do was program the throttle to work from standstill.
Thanks, Gotcha.
You're confusing me, you first said the cheapest way is to get a KT 36V/48V controller and KT LCD. Now you've just said I need an HL Controller and a KT LCD, a new waterproof cable and possibly a new battery case. That's just about everything except the motor. What's an HL Controller?
Thanks again, could you be more specific. For example would the conversion be a straight swap plug and play so to speak. Any wiring problems? Can you supply or are you able to link me to a supplier of the type you suggest. I have just watched a video on how to set the KT-LCD3 up it looks very comprehensive and as you say is very flexible. Something I'm very interested in. Incidentally the bike has been excellent in the time I've had it, a credit to you. I eventually changed the tyres to Schwalbe Space we spoke about some months ago, I like them.
So can I "upgrade" my Rio FB so that this bluetooth adaptor works. I've never been happy with the LCD on the bike.
Thanks for the info. I'm interested in the bluetooth adaptor, I see that you sell it, can you assure me it works ok with the controller on my bike before I buy.
I have found a way of setting off without pedalling. For example, if I arrive at a junction with the throttle applied and brake to stop, if I keep the throttle applied, I can set off again as soon as I release the brakes without pedalling. But be much easier, if it worked as any other throttle worked. Can it be re-programmed?
The throttle on my 2017 Woosh RIO FB only works if I'm moving. In other words it won't start the bike from standstill. Can anyone tell me if this function can be enabled.
cycling with a heavy-ish camera
I have a Lowepro Toploader 50AW II for my Sony A7III and 24-105mm lens. And a Lowepro Toploader 55AW II for the longer lenses, for example it carries a Canon 7D mk2 + 100-400mm mk2 zoom. (heavy) both these bags are supported on the front of the body (very convenient for rapid use) by the Lowepro Topload Harness.....
Woosh Rio fb
Hi, I have one of the above and really like it. My only complaint is the lack lustre LCD display, doesn't even have a clock. Can this be swopped out for something better or am I stuck with it?
richardg6paj
Joined
Last visited
