Lincolnshire lad started following Ross_Dr
Hello from a newbie
Will do, thanks.
Hello from a newbie
Hi thanks, when you didn’t get back to me a few days ago, I thought maybe you’d sold out and not got any left, so I had to seek another supplier, wish I’d have been more patient! That’s what comes with wanting things done today instead of tomorrow! I’ll remember for the next time.
Hello from a newbie
Hi, thanks, good to hear from you where are you based in the States?
Hello from a newbie
Hi Ross, thanks for your pic and info, I’ve looked online and and on YouTube, it definitely gives more info, it’s something I’ll look into when I’ve sorted the gearing, at the moment I’m taking the advice of the other member d8veh and thinking of replacing my single chainring with a triple set up, and I’ll be interested in the Freewheel removal tool if the one that’s supplied with the Freewheel I’m buying doesn’t fit. Regards, Paul.
Hello from a newbie
Hi thanks for your message and offer of the freewheel, the other day when I replied I said I’d seen some on EBay, I’d been looking at the wrong thing.! DOH!!! So about your item, I need a 7 speed 11t-28t Screw on Freewheel can you oblige? What removal tool will I need?
Hello from a newbie
Hi Chris, thanks for your message, I’m sure you’re having a load of good rides on your Cube. I’ve just been looking and some of the models are reduced by over £400. Good deal!
Hello from a newbie
Hi Ross, many thanks indeed for going to the trouble to help. I appreciate your advice. I decided to ring Cyclotricity and they said the chainwheel that’s on it is a “pressed form “ one. They say that any other regular square taper fit chainset will fit. The cassette is a freewheel screw on type, hope this helps. If you like, you can email me some pics of the LCD unit to .... psutton20@googlemail.com
Hello from a newbie
Hi Gaz, I’ve had a look on line at the Coniston, very nice, and good quality.Yes, that’s the trouble, we are always looking for something a bit better or different!
Hello from a newbie
Hi Chris, thanks for your message,nice to hear I’m not the only new kid on the block! What bike have you got?. Paul
Hello from a newbie
Hi Thanks for your reply, what size chainwheel would I need, how many teeth? I’d only put a single one on , about the cassette, thanks for the offer, but I’ve seen some on eBay for about £12.00 Shimano Hi Ross, yes any help and info would be much appreciated,my cassette (7 speed) is 14t-28t and the chainwheel is 44t. I don’t know what the design of the chainwheel is called, but rather than fixing to the carrier with 5 bolts, it is one complete pressed unit with 5 “radial spokes “ meeting at a circular cut out and that mounts on the spindle. Would a replacement chainwheel be the same design or would it be the type that easily separates from the carrier without having to remove the crank pin? If I’m not quite using the correct terminology then please bear with me, as I’m a newbie! Your conversions sound interesting, I did have a look on eBay for hydraulic calliper sets, but all I saw had a really long rear line that needed cutting to suit. About the LCD display unit mods you’ve done, what are the extra features? Cheers for now,Paul.
Hello from a newbie
Hi Ross, I’ve just sent you a message saying I don’t know how to get onto the message page to reply to you. Well don’t ask me how but I’ve managed to find this page!!. Regarding the gearing, it’s very flat around here, so when I’m doing 20mph in 7th ( top gear) my legs are going round in a blur! What I want is to be able to do that speed or even more up to 30mph on the flat and it to feel nice and steady... is that possible? What mods have you made so far.
Hello from a newbie
Hi Gaz, thanks for your message, sounds like you’ve got the ebike bug! What do you think of yours?
Hello from a newbie
Hi, I’ve recently got a cyclotricity stealth 1000w. I live near Mablethorpe. Any other pedelecs in the area can help with alternative gearing?
Lincolnshire lad
Joined
Last visited
