Sutty86
  1. Sorry just seen ,yes that would be very kind , anything to give it a shot
  2. Btw just so you know I'm not going to ride it with the nut on that way around
  3. So I know this is not the correct way to put the nut on but it will not go on the other way around Any ideas how I can fix this , The thread is too deep on the opposite (correct way)
  4. Yes I would need a brass adaptor is that correct?
  5. Be great to have an extended battery
  6. I like the bar ends but seem very expensive when I googled them . Looking to buy a cheaper alternative as my wrists are killing me , went on a battered footpath for 100m and killed my wrists in the process. Think I will have to get a different seat on mine as I'm slightly too short, the suspension seat post is a little to high on the lowest setting. Not the bikes fault just my height Fitted a new inner tube and nearly blew my biceps off pumping it up! Are presta notoriously hard to pump towards the end! I have a little short halfords pump which does both! May invest in a footpump! Made a massive error in fitting my handlebars and basically been riding around the the forks on back to front! One of my friends noticed in a photo I put up! Really impressed with the bike on hills! There's a really steep street near where I live my motorbike used to struggle getting up it and my exs 1l Citroen would! Bike flew up with me obviously giving it some Welly!
  7. Great write up I'm slightly heavier than you at 100kg , going to do a test ride in the next week
  8. Of course , will pm you now thanks again
  9. That's very kind of you , I may aswell buy one on Amazon I think there only ten pounds. Do you think they will do the job. Thanks for your kindness
  10. Thanks pal be a Thanks for the reassurance on the free turning. Did you buy a riser or going stock? Cheers will buy tyres now what size did you opt for?
  11. Great topic about a lovely bike. Looks much nicer in the flesh. I need to paint the silver supports of the mudguards I had a few teething issues but Hatti was fantastic. With the battery I've seen some videos on YouTube were folk have plugged in external batterys into the charge port. I obviously wouldn't try this but maybe an option. What are people's thoughts on the best tyres I have only taken my bike out once so far but my commute is 16 miles and definitely want the best puncture resistant tyres. Had issues with the inner tubes at halfords do we need 80mm presto? My front handle bars I've changed the grips as didn't like the standard ones but notice my handlebar(front stem) moves very freely from side to side is this normal. When bike is on the bike stand the wheel easily rotates to the side, very freely . Which I find quite nervy. I have the standard 8ah and looking forward to putting miles on it. It's very easy to ride with the battery turned off also!
  12. That's very kind and looks very solid Mine looks like this Not sure how to drill the hole out , I have a power drill but no vice to hold the hitch
  13. What's the best way to secure the hitch?
  14. Just bought a woosh faro with a rear hub motor. Axle is thicker than normal bike axles by a few mm. Anyone got any ideas or any companies sell trailer hitches/couplers?
  15. Thanks for the reply both of you, The faro is more my budget and looking for something I could ride unassisted also! I read on another post about in the future adding a battery , I can't afford that option at this moment in time. Would it be an easy fit to had an connector? Plug and play or would it be a return to base fit. I'm 100kg just slightly over the recommended weight ,but losing weight everywhere Lost 16kg since Xmas running
