New Presteigne Rally!
Has there been an announcement from Onbike about TdP 2013?
Aldi Cycle Gear Heads Up
I dropped by my local Aldi before lunch and they had already sold out of the short sleeve shirts, which was the only thing I was interested in. I suspect they didn't have many of these.
Cytronex kit or alternative?
Hi Mark, Would you say the motors are getting better or just different? Obviously you have accumulated enough experience to fix minor niggles before they cause problems. It will be interesting to see what Brompton use if/when their rumoured project appears. I have a DIY Tongxin project, which only gets some attention when I have spare time, so it is mostly just a collection of bits & components. I should stick with the KISS philosophy but I keep dreaming up new bells & whistles to slow progress... Regards, Robin
could kill boyfriend.
Crank pedal threads can be repaired with an insert, but if the crankset is nothing special it might work out the same price as a new crankset. Unless the original cranks were made of soft alloy I'm surprised he was able to thread the pedals on the wrong way round. Highpath crank repairs
Brompton interview
Apologies if this is old news, I haven't been lurking here much of late. There is a brief description of a prototype e-Brompton. Interview with Will Butler Adams Robin
Building a small A123 Battery Pack
Is it possible to use the Turnigy with a remote sense resistor? With a rear mounted battery & controller this would be a more sensible arrangement than having to run thick wires to the handlebars & back again. Robin
Wheel Building - Tongxin in Brompton wheel
The smaller roller brakes were very under-whelming, the IM70 is OK-ish and the new IM80 might be a decent brake. Look at IM80 vs IM70 halfway down page Robin
Not easy to find but there is a roller brake to disc brake adapter available: Cesur disc adapter I don't know if it has been tried on the Tongxin hub. Robin
The splines look to be too big for a centrelock disc mount, so I think it is intended for a roller brake. The larger slots in the pictures of the Shimano disc above are on the lock ring which holds the disc onto the hub. It uses the same tool as used for cassette lockrings. Shimano XT disc hub Nexus hub with roller brake mount Robin
A2B - December
In the latest AtoB they mentioned that Brompton is working on an electric version but it is still some way off. I think I read somewhere that they were also in contact with Tongxin a while ago but I don't know if anything has come of that. Robin
Battery re-cell with Maplins Hybrid D cells
These don't make any mention of being low self-discharge, but for a bike used frequently that is unlikely to be an issue. The component-shop might have the equipment for welding tabs in house so worth asking if you want this option for batteries without tabs. I bought some tabbed 'instant' AAs and a few other bits from there and would certainly use them again. Robin
Has anyone tried to re-cell a pack with hybrid batteries ?
Did you mean £9.99? The price I see online. I did see these D size Hybrid cells in stock in my local Maplin last week but I didn't look at the price, I was just interested to see they existed. Robin
I take it you mean the low self discharge type NiMH type batteries. I hadn't realised they were also better in the cold. Until recently these were only available in AA size but I see Maplin now have in them in D size also. They are definately better for occasional use application e.g. digital cameras. Generally more expensive than standard NiMH at the moment, maybe this will change in the future. I don't know if they are better for the higher current requirement of a ebike.
Mini electrical connectors?
I was told over the phone a few months ago that web orders get free delivery irrespective of size but didn't test that as I was above the threshold (£45 I think) for free delivery for any order. Robin
A hub motor kit with handlebar backlit display
I remember this display & motor catching my attention at the London Cycle Show. At first I thought the motor was a Tongxin. As a DIY bodger I was also interested in the display. The motor seemed quiet with the 'lift front wheel and turn on motor' test but I didn't have time to do a proper test. The Tongxin site seems to be more often down than up so I have attached the picture of their display mentioned earlier. Since they don't usually respond to individual contacts this is of academic interest to most anyway. Robin "LED Display: Speed,kph and mph,16"-28" Distance single, be back 0 Distance total Power capacity, 24V or 36V Lamp Assistant: OFF-LOW-MID-HIGH Blue Background light Auto sleep mode power save Odometer display&its controller(speed,distance,time,Off-High-Mid-Low electric assistant) 0.7Kg 500 RMB"
RobinC
Joined
Last visited
