Everything posted by shaun wyatt
Rubbing rear wheel
I will have a look and get some pics
Rubbing rear wheel
Hi awol, no movement on the wheel at all , if i pick the back of the bike up and spin the wheel there is no noise but if i am on it and even free wheeling the noise is there
Rubbing rear wheel
Hi nealh, I do not have rotors and the bike has been fine for the past 2 years
Rubbing rear wheel
Thanks vfr400, yes checked that, i have turned the bike upside down and spun the wheel with no problems and spokes are tight. i'm wondering if it is coming from the motor. Apart from the rubbing sound the bike runs as it should.
Rubbing rear wheel
Hi, I have a 48v 1000w panda ebike kit. I have started to notice a rubbing noise from the rear wheel which sounds like brake rub.I have remove the rear mud guard and checked the brakes for binding checked the frame for cracks and tightened everything up.if I lift the rear wheel up there is no noise but sat on it even free wheeling the noise is there Hope someone can help Shaun
Battery display
Ok thanks very much
Battery display
I have been charging the battery every 20 miles as i do not know how much is left https://www.pandaebikes.com/shop/batteries/10-4ah-48v-dolphin-type-downtube-battery-lithium-ion-samsung-cells-uk-charger/
Battery display
https://www.pandaebikes.com/shop/conversion-kits/panda-1000-eco-electric-bike-kit-48v-1000w-black-motor-led-screen/ Very Basic
Battery display
Hi,i have built a pandaebike setup, but after riding for about 25 miles the battery gauge still says full on the display.They are not replying to my emails and was wondering where i can buy another one with a speedo function as well.
Puncture proofing tyres
Thanks mate, the weight is no problem as the bike is so heavy anyway:)
So if i put stan's no tubes for example inside the tube of a regular tyre that would be the same protection as tubeless
I have 700c 32 on mine rear motor and to change the back tyre is a right pain.First time out on my new build and puncture
I have been looking for something like this for bike wheels but cannot find anything anywhere
- Screw on freewheel
Thanks for all the replies,i will have a look into it further- Screw on freewheel
Thanks for the replies,i think i will need to run a triple on the front to get the range and 7 on the back.I will get onto sjs to confirm Thanks again Shaun- Screw on freewheel
Hi,i have just received my ebike rear wheel and it has a screw on freewheel,i do not know what speed will fit,is a 9 speed the same thickness as a 7 speed,There is 36.5 mm clearence Thanks Shaun - Screw on freewheel
Back to top
