Can anyone please offer some insight into the pinout and function of the five wires in the Shimano Steps charger-to-battery connector?
My Shimano supplied charger is all I need WHEN I'm connected to AC mains power. However, I'm often away from AC mains for days or even weeks at a time. At those times I have a supply of 12vdc power and I would like to be able to charge my Shimano Steps battery without the inefficiencies of using an AC inverter.
I have a nice DC-DC converter with adjustable, regulated 35-50 vdc output and adjustable current limiting that should be just the ticket - two wires in from my 12vdc source and two wires out to charge the Shimano battery. But, the Shimano charging connector has five pins, not two!
Two of the five pins are larger and clearly carry the charging current. The other three are likely to be communication between the battery and charger, but what do they communicate? And more to the point, what logic levels do I need to apply to those pins when charging the battery?
Finally, while my fallback is to chop the Shimano charging cable, and reconnect it with generic industrial connectors to either the Shimano charger or my own charger, I would much prefer to leave the Shimano charger intact and install a compatible connector on my charger. Can anyone point me to a source of that five-pin connector that Shimano uses?
Many thanks,
Stan
